Android vs Apple
I cant figure out why certain records will crash the tablo app on google tv but play perfectly on Apple TV
There are issues with google tv and if you have a show with at least 100 recordings. It doesn’t happen on other platforms.
Hi @davidrap,
Is it always the same shows that crash? If so, are they part of a series and do every show in that series crash?
Would you describe the crash?
