My apologies if this has been discussed before. It appears as if the Chrome web browser does not have the 30sec Forward and 20 sec backward function. Is this a correct observation?
That is correct. If you are on an Android phone or tablet and using the Chrome browser, you don’t have the skip functions.
If it is live TV, all you do is pause and play. If it is a recording, you can mover the slider bar on the bottom to whatever place in the recording you wish to see.
Thanks snowcat
