My Dad was having a lot of issues with his tablo so I did a factory reset. This apparently deletes the recordings but the android app still shows them. When clicking “delete all” the progress circle spins for a quick second then stops and the same number of recordings appear. If you try to play a recording in the app, it says something like “file not found”. When you try using the app to schedule or unschedule a show, it does not actually set or delete it. Using the roku tablo app to do this works as expected. So how can I clear everything from the app and start fresh? And get the app to talk to the tablo?
Thanks in advance!!
Darren
