An other Playback failed with legacy tablo
I’m having trouble playing back recordings and watching live TV with a legacy Tablo 4-tuning unit connected to my network via a wired connection. It seems to be recording scheduled shows, and the channel scan shows very strong signals from my antenna. The TV guide is complete… I can change its settings. I’ve reset my Tablo and my router. My Tablo connects to my network, but the problem persists on my iPad, my home PC, and probably even on my Apple TV…
Playback failed, Weak signal (this last message doesn’t make sense given the signals received from my antenna.)
Do you get the same issue when you use your phone while near your router? If not, it could be with your wifi between the router and devices. In this order, try rebooting your router, then your Tablo, then power cycle your streaming device(s) to see if this helps.
You might also want to ensure you have the latest iOS app update.
We were renovating our kitchen during that time, which meant I had to move my Tablo. When I put it back in its original spot and reconnected the cable, the problem seemed to have gone away. The problem came back once (very briefly) after that. I probably reset all the devices (Tablo, router). For now, everything is fine. I suspect my router!
Good to hear.
