Amazon Fire TV , Guide To Choose
I researched the best Amazon Fire TV over the past few days because i am looking to upgrade my current setup for better streaming and smart home integration i read reviews on The New York Times Wirecutter Consumer Reports and TechRadar and these two models consistently come up as top picks:
Amazon Fire TV 43" 4-Series 4K UHD smart TV
https://www.amazon.com/amazon-fire-tv-43-inch-4-series-4k-smart-tv/dp/B0B3HG269B
Amazon Fire TV 55" 4-Series 4K UHD smart TV
https://www.amazon.com/amazon-fire-tv-55-inch-4-series-4k-smart-tv/dp/B08P3QB66R?th=1
However i am having a bit of trouble deciding which one would best suit my needs so i would really appreciate some expert advice or feedback from anyone who’s used them.
My needs:
I mainly stream content from Netflix Prime Video YouTube and occasionally play games through cloud services i also use Alexa devices around the house so seamless smart home integration would be great picture quality and app responsiveness are important but i do not necessarily need top tier specs just something that feels snappy and reliable.
Which one would you recommend? Or is there another Fire TV model or alternative you think works better overall?
Thanks in advance for your recommendations!
