how can I get lose captioning on my amazon fire stick?
Am using “Tablo Preview” App on my 2nd Gen Firestick… All I do to turn on CC is pressed and hold the middle Circle ring button on remote for 2sec while on shows… You should see the CC message if you want on or not… I hope this helps… Not sure if this also applies on regular “Tablo” App…
Thank goodness for this reply.
I just got the 4K Fire stick to replace my failing Roku and I would never have thought to try it this way. The Tablo FAQs also was not clear on what it means to " press and hold the select button" - in hindsight it’s pretty clear, but IMO a picture would have saved me some searching.
Awesome! Thanks.
