Amazon 4K Firestick
I have an Amazon 4K Firestick, can a Tablo be used to record programs off it, and is there a DVR app for it to schedule what to be recorded?
No. That’s not how Tablo works. It is an Over-the-Air DVR.
Maybe. Not sure of your question. Yes, a firestick can be used with Tablo. There is an app in the store. You can record over the air TV and the streaming channels Tablo provides only. You need to connect a TV antenna to the tablo for it to work.
Thanks, I just bought a Tablo 4 tuner DVR and set it up today. I found a app called Screen Recorder for the Amazon Fire TV 4K Max that may do what my friend is looking for.
