Is there a way to use alternate port assignments for TabloConnect? My NAS currently uses port 80 and 443.
You could get your router to forward different ports (internal 80 and 443) to a different ip on your network with a different computer using a third party port forwarder (like a hop) and then get that port forwarder to forward that traffic to 80 and 443. I wasn’t able to get custom ports to work… but this would…
@TechNerd Tablo Connect isn’t using your ports 80 and 443 - those are the Tablo’s ports. The port mappings you need free are usually uncommon and free. They’ll be listed in the Settings page if you need manual configuration. Hope this helps!
