I have a recording that I can see on my iPad, my Android tablet, and my Roku, but it doesn’t show on the Web app despite which device I’m using. Anyone know a fix for this? It is my most recent recording of SNL. I have verified I can play it via the iPAD and Android tablet, so I know it’s actually there… it’s just not in the list on the web app.
First, look closely at all the dates of the recordings and the episode numbers. The Web app doesn’t sort correctly, and it will put episode 10 ahead of episodes 2, 3, 4,etc. I was worried myself when I was trying to find the latest Cosmos show, and since it was episode 10 last night, it was listed before all the others.
Thanks… but that’s apparently not my issue. I have only two recordings, and when you select the TV show on the Web App is shows 1 episode recorded, and it’s not the one I’m looking for.
Did you delete though? Disconnect and reconnect does not do a sync. Only a delete and re-add will.
@Rich - @snowcat is correct on this one. Try deleting your Tablo from the web app. Then go through the scan, add, and syncing process. Let me know if this solves your issue - we’ll investigate in the meantime.
@snowcat, I thought I did disconnect and reconnect, because I had to go back to the basement to get the Tablo to connect as the WiFi signal from the Tablo isn’t strong enough to reach to other places in the house. I just repeated this effort now though, going through disconnect, deleting the Tablo, and then reconnecting.
No, the disconnect will not affect port mapping. What will affect port mapping is if the IP Address of the Tablo changes. I had that problem for a while before I finally went into my router and gave the Tablo a static address.
@snowcat that is definitely a bug – you shouldn’t ever have to refresh. If you are ever able to reproduce this issue consistenly, do let me know. In the meantime I’ll look out for this behavior.
It hasn’t happened often, but I will be on the lookout if it happens again,
@snowcat, thanks again.
@Rich, I had that happen once, but it’s been over a month since it happened. I lost all my HD channels, yet I could see my SD ones. I had to hit the reset button on the Tablo, and that fixed it.
@Rich you’re not the only one who is having issues with some recordings (or data in general) not showing up in the web app. I am actively investigating this.
A web app update is forthcoming with some other fixes, hopefully I can track something down for that release.
@Rich an update to the web app was pushed out today. Among the changes implemented are some robustness fixes to the sync process. I’m now able to hit refresh or even disconnect the network during sync process, and it’s capable of recovering without a hitch. I’m hoping that solves some issues, but I won’t get my hopes up just yet! Let me know how it goes.
If for any reason your Tablo is SYNCING in Chrome browser and you don’t let it finish and give it time to complete its thing and take off say with your device, I have found some recordings don’t show up away from home. Not only this, but if you come back home and launch Tablo on your laptop etc. it still doesn’t have all the recording. So, if you do as Snowcat said and delete the Tablo and allow it to resync and be PATIENT, everything will show up. All this may have something to do with the speed and quality of your WiFi would be one guess I would throw out there. Bottom line, is be sure while you are at home you see all your recordings before hitting the road.
Has there been a fix? My issue is I can see/use my Roku and iPad with full functionality and no issues. The Web App (using Chrome) is unable to view recorded video. I get audio but just a black screen in the browser.
Disregard my last - I think my Firewall was causing problems. All fixed now.
