AirPlay of local channels don’t work
I’m trying to use Tablo to play local channels on my TV and I’m using my phone to navigate Tablo and using airplay to play on my TV but the local channels only play audio through my TV but plays video on my phone when I switch to a non-local channel that doesn’t have a problem with playing video over airplay
I’ve experienced the same. Not sure if this is expected, but would be great to be able to airplay while the ATV app is in beta.
I found an explanation in the topic Tablo iOS Mobile App (4th Gen) Update (v. 1.4.2 & 1.4.3) - #11 by TabloTV, where there’s a post from Tablo:
"Unfortunately this is another symptom of Apple devices not handling playback of MPEG2 video. The AirPlay button should be disabled when you’re playing back live antenna TV or completed antenna TV recordings when you’re using expanded storage as this would result in the issue where it would cast the audio but not the video.
Free streaming channels and completed recordings on onboard storage that have had time to be archived as MPEG4 video should offer the AirPlay option and should work as intended."
This makes me wonder whether the app for Apple TV, when it’s released, will even be able to play live TV or recordings on external storage.
Can someone from Tablo respond to this? I submitted a question to support, but got the following unhelpful reply from an automated assistant saying:
“The 4th Generation Tablo DVRs can decode MPEG-4 broadcasts thanks to a firmware update. This means that you should be able to play live TV on your Apple TV 4K using the 4th-gen iPhone app, provided the channels are broadcasting in MPEG-4 format.”
Clearly, my problem is not MPEG4, but MPEG2 video. I’m hoping that a human will eventually reply with a better explanation of MPEG2 on Apple TV devices, because if the Apple TV app will never be able to handle MPEG-2 video, then the entire 4th-gen ecosystem will be problematic for Apple TV users.
Its kinda crazy… That the Channel DVR Server doesn’t support Roku for the opposite Transcoding reason. .
Tablo is trying attempt something. Of course it’s taking a while. But, Channel DVR is a no go for Roku.
Hello,
Sorry for the trouble you’ve had with support. We’ve updated them, and they’ll reach out to you soon.
As for your question our Apple TV app will be able to play and record live TV.
