When using iOS to AirPlay to my AppleTV, and I getting double compression? I realize the Tablo already compresses the OTA signal from MPEG-2 (19.2 Mbps 1080i) to H.264 (10 Mbps 1080p), but will using AirPlay re-compress the H.264 stream to a lower bitrate?
Also, does AirPlay hand-off the stream URL to the AppleTV, or does the stream still transmit through the iOS device?
As far as I can tell both Airplay and Chromecast stream at the same rate as the device you are streaming from. So there is no extra compression.
Well with the “Roku 4K” rumored to be imminent, that would presumably support H.265. Same with the rumored AppleTV update, whenever that launches. I wonder if the current Tablo hardware could handle that transcoding (my guess is not…at least not real-time).
My understanding as there is no Apple TV app for Tablo that the streaming goes Tablo to router, router to iPad, iPad to router, router to Apple TV.
It unfortunately does not result in the Apple TV directly streaming from the Tablo.
Some hardcore picture guys have had success turning off the motion blur settings on their TVs.
