Google store TABLO app will not install on my Sony android TV.
There is no direct link from TV menu. I can open from Google Store, this is a way too far back door route.
I’ve reset devices, cleaned cache, powered down but can’t get an app to work on this TV.
My Roku TV works seamlessly.
On an other note, the LED on the Gen4 stopped. Unsure of a relationship.
Hi @Daniel_Rem ,
Just to double-check, would you let us know what version of the app you’re trying to install, 4th Gen or Legacy?
Sideloading?? See my LG TV response from today with another user.
I would be trying to install the Gen4 App on a Tablo TF1282B-01-CN device.
Would you reach out to Tablo Support? They should be able to investigate and help.
I have a Sony x90L tv and experienced no problems after updates. Doesn’t help you I know but letting you know it’s not widespread.
