Adjust recording time disables recording?
Hello Tablo peeps!
In the past couple of weeks I’ve gone into a scheduled recording settings to try and adjust the end time to be longer. (Because of sportsball crowding in)
I believe I’ve adjusted correctly, yet in the last two tries, it’s as if I commanded it to just not record! There’s no recording later.
I consider myself to be well seasoned on making such adjustments, so I’m going to carefully test moving forward, but wondered how many others have noticed the same?
Using two tuner Tablo 4th gen on a Roku Ultra.
Is the extended recording now conflicting with two already scheduled recordings? If so, it might not record.
Thanks for the suggestion. I did see a conflict at one point, but I could have sworn I resolved it. If memory serves, that happened the first time. I don’t recall this happening the second time. But I’ll have to be more diligent about checking for that moving forward.
