Hello,
We live in a higher elevation where we get several channels from different markets. IE: Albany, NY and Burlington, VT. Is there any future plans to support more than one area?
Hello,
@ummhello1 - If you can get the channel, you’ll be able to get the guide on Tablo. We may have to get the data associated with the zip code you’re using but it will work!
Hope that helps answer your question.
What email do I send the channel data to?
You can email support@tablotv.com or use the ticketing form on the knowledge base. http://support.tablotv.com/hc/en-us/requests/new
