Ad Provider Platforms
@TabloTV
I use a privacy DNS on my home network. I recently had to add doubleclick.net to the allow list to get my Paramount+ service to work. I’d also like to add the Tablo advertising providers to this Allow List.
In evaluating the DNS logs, I see 2 main top level domains that I might need to add: wurl.tv and amagi.tv. Are there other domains I should be adding to the Allow List? Or are these it?
Thanks!
Wurl and Amagi are their Fast Channel Servers.
The ads on those channels are built into the stream.
You can find a decent “allow” list, it will have all those links whitelisted for streaming companies. Tubi has a butt load of them.
Right. I’m just curious if those are the only two I should be adding to the Allow List?
They should not be on any block list. So you should be good.
Edit: if they’re blocked, then you overloaded your list’s and added too many. Which can happen.
Looks like you’re right. The DNS logs are showing me those two domains are being fully resolved and not blocked.
