That narrows it down further! PBS channel 12 is hi VHF; ABC channel 6 is lo VHF. The C2’s VHF component is hi VHF and will pick up PBS fine.
I’m not sure what the amps will gain you on ABC because you are so close to ABC. Try them but you may need that lo VHF antenna that @jberting mentioned.
