I have had the 4 tuner model since May, 2015. Last week, it started getting an error when connecting from a PC on the same network: “A connection to your Tablo could not be established. Please check your internet connection.” Roku boxes, too, could not play content. IOS devices get the same error message as the PCs.
Power cycling seems to cure the problem. I also did a full factory reset and that rectified it as well. However, the problem always returns after approx 12 hours.
I called Tablo support. They confirmed my device was contacting their server (via MAC address). They told me to power cycle my router. They wanted me to call back and queue up for another call. Power cycling my router did nothing.
Any advice out there in the user community?
I have ordered my HDHomeRun and am ready to move on at this point. Too bad, as I really liked the Tablo.
That used to happen to me as well. Same exact issue and power cycle to fix. Since upgrading to a new router (My old one was old) have not had this happen since, for over a year now.
I have a relatively new Unifi Security Gateway (USG). The problem started happening several months after its installation. Unless Tablo has some undocumented ports, all firewall and forwards are set properly. I am not convinced this is a router problem, particularly since resetting the Tablo (without restarting the router) gets things going again. In any event, if the Tablo is incompatible with the USG, it’s another reason to move on.
Thanks for the feedback. I am glad it corrected your issue.
I had the same problem it wouldn’t connect the problem was the wifi inside the Tablo went bad so I bought a new Tablo when the new one came in It had a cable to hook it up directly to the router so i hooked the old Tablo in and it worked. That’s how I know the wifi went out on it. The problem is the antenna is coming in the house from the ground floor and the internet is on the second floor. I used YouTube and found out the wifi card used in the Tablo but I think I am going to run a antenna cable to the wifi router and use it the old one also. Or I might see how much a friend will charge to solder in a new wifi antenna on the Tablo.
@JohnBoy5562, thanks for that insight. I have it connected via the RJ45/Ethernet jack, no Wi-Fi. Perhaps this is the point of failure - the hardware. I will try to set it up to use WiFi (didn’t realize that was an option).
*** Just tried to replace the Ethernet cabled connection with the built in WiFi. The Tablo couldn’t connect. I am beginning to strongly suspect that after close to 3 years of service, it is failing.
I’m also having the same issue on my Android Tablet and Firestick when access my Tablo Dual. It seems to have started when I upgraded to the latest Tablo App on both devices. Rebooting fixes it for about 12 hours, then it hangs up. I have noticed there is always a recording in progress when it happens.
Same thing on my end. I’ve been getting the “A connection to your tablo…” error message for the past few days but I’m able to http to my Tablo without any issue directly from Chrome (http://192.168…/pvr…). Nothing changed on my end (no hardware/software update). Tried rebooting my router and Tablo; no success…
I tried all of those steps last night after my two Amazon sticks quit connecting after the new firmware update. No success.
I even unplugged the Tablo, left it unplugged, uninstalled the Tablo app from one of my Firesticks then reinstalled the app. When I told it to scan for Tablo’s, it couldn’t detect it, as it was still unplugged. I then plugged the Tablo in, waited a minute or so and then did another scan and it detected my Tablo. So I don’t think there’s an issue between the Firesticks and the Tablo. I believe there’s an issue between the Tablo and the “outside world”, otherwise I don’t think the Firestick would be able to detect the Tablo after reboot/reinstall of the app.
Rebooted Tablo, power cycled Tablo, rebooted Router… Nothing works… I can list my old recorded shows on port 18080 but I get the “No Tablo” page through my.tablotv.com… Any help would be appreciated…
CHECK THE WIRELESS CONNECTION BEING USED BY YOUR APP! If, like me, you have more than one wireless connection in your house, perhaps one called _2G or _5G for example, make sure everything having to do with your Tablo is using the same one, including your AppleTV.
I suddenly had this connection problem today with my Tablo. Windstream recently upgraded my network speed, so I wondered if that was behind the problem. After trying multiple troubleshooting steps, including restarting the modem, router, Tablo, and AppleTV, nothing helped. Finally, it occurred to me to check what wireless network my AppleTV was connected to. Eureka! For some unknown reason, the Apple TV had connected itself to a different wireless connection in my house than the one the Tablo is connected to, the one with a 5G added to it. As soon as I reconnected the AppleTV to the one the Tablo is connected to, the problem went away.
