Nice find. But you can get a brand new Roku 2 Model 4210 for $69. So brand new and the same internal hardware specs of the Roku 3 Model 4200 for only $6 more.
www.amazon.com/Roku-Streaming-Player-4210R-Processor/dp/B00UJ3IREE
It’s different
look at the features
The only difference is the remote
I don’t know about you, but these are all important to me… Especially being able to point the remote anywhere
That chart is for the features of the new Roku 3 Model 4230 released in April 2015. The link you provided is for a refurbished Roku 3 Model 4200 released in March 2013, which does not have Voice search.
But yes I do like the WiFi Direct Connect remote of the 4200 and 4230.
Remove voice search from my requirements
But I need to be able to point anywhere lol
Ok yes, if pointing it at the ceiling is a mandatory feature then the refurb deal is good. But if you don’t care about the remote, then the new Roku 2 is a great deal too.
Based on recommendations I just bought the 2015 Roku 2 and will plug it in late tonight after work. Thanks for the tip tu86
Don’t need headphones or point anywhere remote. If Suri and a Magellan GPS have taught me anything, it’s that voice commands usually never really work as intended.
The headphones was a Wife requirement for me
Wives, always causing problems.
