Is the 4th Generation Tablo compatible with Firestick? When I try to upload it I get “unavailable” message.
You have to make sure you are using the 4th generation app and not the legacy app. The legacy app is white while the newer app is blue.
Hi. The 4th generation app is the one that says “unavailable”.
If you’re using a 1st or 2nd generation Fire TV stick they aren’t powerful or fast enough and therefore are not supported.
You can see a list of supported Fire TV devices here:
Thank you!
