I purchased this 4 tuner 4th gen Tablo less than a year ago. It has been increasingly unstable recently. It would show that the Tablo could not connect but would immediately connect after restarted. I needed to restart it several times a day for the last couple of weeks and today I noticed no blue light and it was cold. It will not power up after reconnecting power. I have tried another outlet with no luck. Has anybody else had this problem and did Tablo replace the defective Tablo.
Would you consider reaching out to our technical support team: https://tablotv.com/support/#contact ? They should be able to assist.
I have done so but was unable to get it going. Hoping for a replacement soon. Unfortunately, 1.5 TB of recorded programs are gone.
You might want to try a new power supply. If Tablo sends you a new unit, try the power supply on your old Tablo. If it works, you’ve saved your recorded programs.
