4th Gen: Unable to connect
Hello.
Today, I had an odd issue, I was unable to connect to my 4th Gen. I tried rebooting the unit, but that had no impact.
I tried clearing the ‘cache’ in the App Settings on Fire stick. That didn’t do anything.
I then also cleared the ‘data’ in the App Settings. Clearing the Data allowed the Firestick to
connect.
So, if you ever have a problem connecting to your Tablo, try “Clear Data” in your Android App Settings :slight_smile:
One thing that has shown to help with this is always closing the app using the back button until it prompts you to exit.
A force quit and cache clear work very well, and since the TabloTV app uses zero login data you can erase that too. Nice tip – glad it worked for you!
how do you clear cache on a firestick?
i can not get the tablo to accept my password and to get it tto start aany help?
This article should help: How to reset your password for your Tablo 4th Generation – Tablo .
Home > Settings > Applications > Manage Installed Applications
