4th Gen Tablo NOT working with Roku update 15.1
This morning (3/14/2026) my Roku updated to Software version 15.1, The Tablo no longer works. I removed the app from Roku, re-installed the Tablo app, still does not work with Roku 15.1. What a deal … Seems like Tablo would have tested their Roku app with 15.1 and released a new version of the Tablo 4th gen app.
I’m about done with Tablo, This is the second Tablo gen 4 (4-Tuner) that I have had with in the last 8 months. The first Tablo just stopped working after only 2-3 months. The current one (2nd one) has lost recorded content that I can no longer access. This product is Beta level at best. I would go back to Tivo, but Tivo is no longer supporting general users anymore. I’m thinking a PLEX server is the way to go, Comments ?
You didn’t say which model of roku you are talking about. Even my ancient 4200 has had 15.1 without any problems for a number of months. What does “no longer works” means in relation to roku OS 15.1.
Sorry about that, should have included more info, I’m using the Roku Express. Until the update to 15.1, I was able to access the Tablo with no issue with the exception of Some content that I can no longer access (TV Show). Do you know if there has been any issue using the Roku Express ?
Thanks for the help
Steve
Now with 15.1 installed, the Tablo App will start and crash, No Access
I’m wondering if this issue is a memory issue with the Roku. The one I have only has 32MB of memory. I’m going to try another Roku with more memory and see if that fixes the issue. One more try before giving up on the Tablo …
Thanks
Steve
I don’t think they have built a roku with less then 512MB since 2015. Once of these models
HD-only Roku streaming sticks may exhibit intermittent issues with displaying content and are generally not supported. The current Roku Streaming Stick Plus (4K) (3830) is also not supported as it does not have the video codecs required for playback of over-the-air TV. Other older low-end Roku devices and those that do not support 4K (for example, the Roku Streaming Stick 3800 and Roku Express+ 3910) are also not supported.
https://support.tablotv.com/hc/en-us/articles/13954983793940-Tablo-Compatible-Apps-and-Devices?_gl=1*odpcoc*_gcl_au*MTY4OTM0MzQwLjE3NzM1MTUxOTU.*_ga*NzYwNDUxNjA5LjE3NzM1MDk2MDc.*_ga_FJZJTK8CDQ*czE3NzM1MTUxOTQkbzEkZzEkdDE3NzM1MTUyNDIkajEyJGwwJGgw
The Roku I have is a Walmart Version, when I look up the model, it says 32MB memory. Could be a low cost version to sell at Walmart.
Walmart versions are stripped down versions of the real roku model. But they do usually have an actual model number 1 off of the real roku model. And you usually can’t find any documentation on the roku WEB site.
Maybe you can uninstall any unneeded Roku channels to save memory and possibly get Tablo to work?
From Tablo support:
I would guess it is the Roku Express that is the problem not the Tablo.
UpDate - I replaced the Roku Express (Walmart Brand) with 32MB of memory, with a new Roku Ultra with 2GB of memory. Still have the same issue, Tablo will start and crash. This started with the update of Roku version 15.1. I uninstalled the Tablo app, re-installed it, still have the same issue. So its not a memory issue, going from 32MB to 2GB and still have the same issue, it must be the new version of Roku 15.1. It was working fine until the update.
I’m going to rey one more thing, and thats to reset the Tablo.
I dont expect any change …
Re-setting the Tablo had no affect, the same issue still exists.
My 4660 ultra OS hasn’t been updated since the end of January and is on 5.1.4.3321(from the check for updates menu).
My gen 4 roku app version from settings is 1.3.2-734366.
My Status - Tablo TV has the tablo unit as checked in with details.
Zippy; do you have any external storage on your gen 4 Tablo, also is the Gen 4 Tablo a 2 tuner or 4?
Thanks
Steve
Since I have multiple legacy gen 1 units so it’s not like I really needed it, so my gen 4 is a 2 turner using internal storage.
I’m assuming you can access the gen 4 using a phone or tablet since it’s been through setup.
My 4200 and 4210 roku’s still work.
So we do have some differences, I have a Gen 4 4-Tuner with 8TB external storage. My last 4-Tuner Gen 4 stopped working after 2-3 months. My current Tablo Gen 4 only has lasted 5 months with no issues until the Roku update. You would not think there would be any difference between the 2-tuner and the 4-tuner, but maybe there is.
Thanks Zippy
Regards Steve
Apps are usually coded to a specific version and feature set of OS API’s. When the app makes a call to a missing set of functionality it blows back to the roku menu. With the gen 4 on the fire tv stick gen 2(non-4k) it blew back since that older release of FireOS didn’t have the required API support.
But who knows with your issue.
Found something interesting, I decided to just try my old Gen4 4-tuner Tablo (The one I had problems with after 2-3 months), I connected it to my network, this time NO external storage, just the Tablo. After a firmware update, its working with Roku version 15.1.
Thinking back, the time this Tablo stopped working, I was at about 4TB of recorded content, this time with the new Tablo I was at about 4TB of storage. I’m wondering now if something that recorded last night tipped me over on some type of limit on storage. The Tablo web site says the Tablo will support 8TB of storage, but maybe there is a bug with large storage.
Comments ?
Steve
So the conclusion is: Its not Roku 15.1, its the Tablo, Dont know much about the 2-tuner version, but the 4-tuner version has what looks like an issue with external storage at about 4TB of recorded content. Tablo says they support 8TB of external storage, I dont think so.
My conclusion is Tablo is a Beta product at best. I’m going back to my Tivo (with External Storage), never had an issue for almost 20 years, always worked right out of the box. Tablo on the other hand, two Gen4 4-Tuner Tablo’s later, nothing but issues. Will most likely be looking at a PLEX server in the future. To Bad, I had hopes, but it did not turn out good …
Thanks for all the comments, and help …
Regards
Steve
Although the is not a direct comparison I had very similar issues with my upgraded Legacy Tablo using the gen4 Roku app. The problem seemed to be related to too many recordings or perhaps some problematic recordings. See the post linked below, perhaps the Roku app behaviors you see are similar.
