I’m glad things are getting slowly better, but I’m still confused on how you determined it wasn’t the hard drive.
I got my 4-tuner today, and recording 8 and watching another I had zero problem. Back on the one with a drive inserted and I can’t even get through an episode of Jeopardy without constant buffering while it records two shows.
I now have two out of three on just flash memory and both of them run without any buffering, no matter what I throw at them. I’ve just tried this on two Rokus, one GoogleTV, and the Walmart onn without an issue (I’m not worried about the Firesticks.)
IDK what happens when you pull out the hard drive, and try to record without a reboot. Not sure where it would put the timeshift, and maybe because it didn’t get stored, it was only in RAM? These Tablos operate in mysterious ways. I can unplug one while watching a show and it’ll continue for over 30 seconds! When the servers went down I could continue watching, but if I exited the app I could not connect.
It sounds like you’re putting so much energy into this and it’s killing me to hear how nothing seems to help. You said that there wasn’t much on the drive, and I don’t want to keep pushing you toward that, but there should be no reason you’re having an issue on that many test devices! That’s a lot of work… wow!
I’m going to assume that the new Samsung you want to buy is going to have Tizen, and if it does, there’s no Tablo TV app for it yet. I hate to see you in the same boat, hoping that a new TV will fix your issues when you still might need a Roku or Firestick.
I wish you luck, but I’m out of ideas. :). I’m holding off on a new drive with my 4-tuner until I do a little more research. I’m tired of buffering and even though my drives aren’t that old, I’m going nuts because of it! TBH, Tablo had that “recommended HD” list, but for weeks it was a 404 error, so I haven’t looked in a while.
I just don’t want you to get so overwhelmed that you give up. I can’t imagine doing all that you’ve been doing just to try to get it to work.
Keep sharing your experience – I await every post!
Edit: I wish hadn’t had that much on my drive before deciding to switch back to internal. I had to copy over and merge over 200G of recordings! Thus, the hesitation about starting again with a new HDD or SSD.
