4th Gen Tablo App misspells "Catchy" as "Cathy" and doesn't work
Same as the title. I’m in the New Orleans area and while I appareciate the polished look and the guide in the new app, not being able to have “Catchy” is major issue.
When doing a channel scan, the scan will initially show the channel with it’s correct spelling but once the scan is saved and you attempt to access the channel from the guide it’s misspelled as “Cathy” and does not work, it generally says “unknown error” and then the app crashes and closes.
This is not an issue on the legacy app but I would like to use the newer app because using both causes a bit of confusion for my older relatives.
I had typo, It missspells to “Cathy” after saving it.
Hi Folks,
We’ve tweaked the channel data on our end. If you don’t see ‘Catchy’ right away, try unchecking the channel, saving it, then re-adding it and saving it again.
Is all of this still on Gracenote? I saw Court TV change to Confess by Nosey but the guide will never change to the correct channel, not in this economy.
Thanks for the reply, I have the logo but it still says “Failed to load, A network error occurred.” when I select the channel.
Hi @AlDente,
Did you reach out to Tablo support? They should be able to help.
If you did, would you DM us the ticket number>
That is strange, @Guess,
When you ran a rescan, did you uncheck the channel and save the changes? Then did your run a rescan again and save after rechecking the channel?
I just did that exactly as you explained and it’s saying “A Playback Error Occured” on screen.
@Guess
This may be due to your tuners being overpowered.
Switching off your Tablo’s TV amplification, or any other amplifiers you might be using, may help.
ok I’ll give that a try
ETA I’m using a legacy tablo, so I don’t have the option to turn off amplification, I turned off my antenna’s amplifer and it made no difference.
Are you using Legacy Tablo with the legacy app? Then you do not have the built in amplifier as an option. But if you are using the Legacy Tablo with the 4th Generation app you can turn the built in amp in the settings.
I mentioned that in a previous post. I was talking about the amplifier that came with the antenna.
I’ve done multiple channel scans, I’ve adjusted my antenna and I still get A Playback Error Occured when attempted to watch Catchy
Sorry @guess. We’re not quite sure what’s happening. Everything seems fine on our end.
We have tried to contact the broadcaster but haven’t heard back.
Have you attempted to reach out to them?
I’ll try to reach out to them but let me point out, the channel worked fine on the legacy app.
tried contacting them and nothing…
The channel worked fine on the legacy app.
