Just like the subject says. I would appreciate if we had a software interface to the tuners on 4th Gen Tablo devices to troubleshoot reception issues, including a signal strength meter by physical or virtual channel, whichever makes the most sense from Tablo’s perspective. It is still puzzling to me that I’m picking up certain stations on every OTA tuner in my house including my Legacy Tablo 2-tuner but not on my new 4th Gen Tablo 4-tuner model. I’ve reached out to support about it and I’m told that it’s weak signal but I’m sure that’s not the case. I’m guessing that it has to have something to do with the way the channel is delivered OTA and the ability of the tuner to process it. I think additional data on the end user end would be able to assist us better in communicating our issues to support and assist them with resolution. Thanks for listening.
Absolutely agree. I believe this is already entered in the Feature Requests thread.
It should always display physical channel. I’m in a situation where there are multiple broadcast towers for the same virtual channel within a 25 mile radius. This is the case for literally every major network. Seeing the physical channel the Tablo tuner is actually using would be helpful in tweaking my roof mounted antenna. It really isn’t fun climbing on top of a two story property to make adjustments. Right now, I’m using a separate OTA Turner to fine tune and just crossing my fingers that Tablo I behaving as expected.
