4th Gen - Can't watch a second channel when recording
I have a 4th Gen. When I am recording one channel, it tells me that no tuner is available to watch something on another channel. I have verified that there is not another recording at the same time. Any ideas on how to resolve this?
Welcome to the TabloTV Community. This sounds like it should be a Support request.
https://support.tablotv.com/hc/en-us
Might be worth opening a support ticket. I would suggest restarting the Tablo first, though. See if that helps.
You didn’t say, do you have a 2-Tuner or a 4-Tuner version? Also, I don’t suppose that someone else was watching something on another TV, were they?
I was thinking the same… sounds like a 2 tuner with something else is using the other tuner.
I had a similar situation. I found that I was recording during the previous hour with a 5-minutes extended stop time. I needed to do this because my Tablo stops before the actual end of the program.
Go to settings, channels, and delete the low resolution NBC, ABC, etc.
In old gen., you can specify the channel to record from.
In 4th gen., it will record from two channels at the same time using both the dual device channels.
The first channel is the old NBC low resolution and the new one is the HD NBC.
You don’t have an option any more to chose the channel.
Yes you do. I do it all the time. I can choose between any channel and the specific channel. I of course choose the specific channel.
Hi Hammamis,
Our 4th Generation Tablo does have an option to choose a specific channel for recording.
The details are here.
