I’ve setup gparted to copy my Tablo drive to a new 5 TB drive. It’s going to be a long process. I couldn’t find a way to change the sector size from 512. From what I’ve read, the drive will handle the sector size difference internally. I started the copy at 1.00 MiB, if that that makes sense. It added that automatically, instead of starting at zero.
201509061614 edit: I originally copied the Tablo’s “msdos” partition table formatted drive. After reading the error in the gparted.htm file, I had the tablo format the new drive. It’s now “gpt”. I then copied the old Tablo drive/ “msdos” partition into the new drive/ “gpt” partition. I could have created that “gpt” type partition table in the new drive in gparted, I’m sure. We’ll see if that does the trick.
201509062108 edit: 29 hours remaining.
201509081830 edit: Success: that was 29 hours remaining of copying the first drive to the second. This apparently happens in four stages; stage 1: check and fix errors on the first partition (drive). Stage 2: (which I failed twice, until I decided to save the error log “gparted.htm” as mentioned above); copy this first partition to the second. Stage 3: check the new partition for errors. Stage 4: extend the new partition to fit the whole drive. This took several days. I’m setup to record Colbert tonight. Everything appears to be working and has been transferred.
Best of luck … this is how I transferred my recordings from my 1TB drive to my current 3TB drive.
