Pretty sure 140 episodes of sanford & son disappeared. Looks like the tablo is planning to re-record them all. I don’t think they were deleted intentionally but can’t be 100% sure at this point. software 2.2.28
It would be extremely unusual for a single series to disappear, leaving the rest untouched.
Are you seeing this across multiple platforms or just on one? Have you tried deleting/re-adding the app on affected platforms to see if they show up again?
If they don’t re-appear, we can take a peek at your logs if you touch base with support to find out when/how/why they were deleted: www.tablotv.com/ask-tablo/
Edit: Yesterday about 200 episodes of Caught in Providence self deleted. I will email logs to support asap. I turned off “auto deletions” afterwards fwiw.
18 seasons of 412 episodes of SVU recorded on my Tablo. All properly processed with commercial skip.
in hindsight it seems the shows' deletion may have been related to an impending hard drive failure . Recently I have copied the failing-drive's contents onto a new drive successfully - all recordings intact and usable with commercial skip. I have not seen shows 'self-delete' again and have re-recorded and recovered all the Sanford & Sons that had disappeared :)
