Just installled the Xbox app a can’t exit the app without turning off the console. A bit annoying. Assuming I’ve missed something as an Xbox novice. Please help! Cheers.
Are you using the Xbox controller as a remote? The Guide (X button in the middle of controller) button will take you to your home screen.
Thank you for your reply. I have tried the Xbox button (not the blue x) I think I was holding too long and pulling the turn off controller or console pane. Pressing more quickly resolved this. Thanks again.
