Does anyone know how to connect Tablo to a Luma router through Ethernet to reduce frequency of the dreaded “loading” screen?
You can connect the Tablo directly to the ETHERNET OUT port (aka LAN port) on one of the Luma devices. See below.
I assume your Luma is directly connected to your modem from your ISP? And not to another router?
The luma I want to connect the Tablo to connects to the modem through the Luma network. Ultimately the Luma connects directly to the modem. Not sure if that answers your question. Thanks for your help.
