Will Tablo support the Android TV/Nexus Player platform with either the Android app or the web app ??
Eventually - it’s on their to do list per Tablo.
don't hold your breath for anytime soon
You can use the Tablo web app, but you need a mouse for it to work on the Nexus player since its looking for touch input.
You have to use APK backup to make a copy of the APK from your phone, you then have to send it over to the Nexus player via ES file explorer. Then you can install it to the Nexus player. It works great.
You must have Chainfire Side loader installed on your Nexus Player for it to work.
