I’m about to give up on Tablo TV. I’m10 or so days in and have yet to get even a marginally acceptable functioning system. Using gen 4 with a Firestick and Samsung tv. Upgraded my antenna to a longer range boosted model to pick up major network local channels. I can watch network news live and record and play back with no problems. But the local news on the same channel that is scheduled just before the national news pixilates and crashes. Playback fails and returns audio decoding error. Shows just after the network news are too pixilates to watch also. Morning shows are unwatchable but some evening shows on the same network are fine. How can a channel work perfectly for one show but fail for another with all the same setup and conditions? I also have to manually pair my Samsung sound bar with my Samsung tv everytime I turn the TV on since installing the Tablo. I’ve tried all the reboots and updates and setting changes suggested for both issues. I’ve set it up with Wi-Fi and Ethernet connections and rebooted my brand new 3 months ago router and upgraded my Internet speed and modem. Is this system always going to be hit or miss.at best? Is it ever going to work as advertised? Because after 10 days of this, I’m pretty much calling it quits and returning the unit. Trying new things to save money is a good thing but paying for something that doesn’t do its job is not an option for me.
Would you mind posting the RabbitEars.info Signal Search Map link of your location?..along with the antenna model you’re using? This will provide a starting point. Also, what model of FireTV Stick are you using? How old is the Samsung TV?
Recommendations from ChatGPT based on your reported issues…
Four recommended tests:
1. Play the same failed recording on another device. Use the Tablo app on a phone or tablet. If it fails at exactly the same point, the recording or broadcast stream is likely the problem rather than the Fire TV Stick alone.
2. Compare direct antenna reception against Tablo. If the local news looks perfect using the television’s built-in tuner but fails through Tablo, investigate Tablo’s tuner, recording, or processing.
3. Enable Audio Compatibility Mode in Tablo, if available. This changes how Tablo handles audio for future recordings and could address the audio decoding errors.
4. Restart the Fire TV Stick and clear the Tablo app cache. Under Fire TV Settings → Applications → Manage Installed Applications → Tablo → Clear Cache. Avoid the Clear Data initially, since that can require setting up the app again.
I don’t know if this will help but here goes. It sounds like OTA signal trouble. It is so critical to recording. You could be getting competing signals caused by multiple transmitters from different directions. You could need to install a 4LTE/5G filter inline. You may have to strong a signal and need to turn off Tablo onboard amplifier or to weak due to long a coaxial cable and need to turn it on. You’re going to need to do some good old fashioned troubleshooting, but start with verifying OTA signal stability without Tablo included. Go straight to your TV due scan and spend time watching all the OTA channels long enough to verify stability. If that’s good then move to Tablo install. If Tablo streaming works fine then it points at OTA signal but if you can’t get it to run on a TV you may have to run an other than TV app program like Roku. I did for two TV’s. But two ran it with no problems
. Hope this helps.
The TV broadcast spectrum now ends at 608 MHz (Channel 36), while modern low-band 5G and LTE cellular signals start right above it (around 617 MHz and higher).
Older LTE filters only blocked signals starting at 700 MHz, making them inadequate for modern 5G interference that dips down to 600 MHz.
At any rate if there was any LTE/5G interference it would be on the upper channel 36 only.
Competing signals are unlikely for full power stations. Not to mention an FCC violation.
I suspect that the correct positioning of the antenna would be the first step.
If we knew the OP zip code it would help.
I agree, this sounds like a signal problem, not a Tablo problem. The first thing I would try is turning on and off the various signal amplifiers. Both too little and too much boost can cause pixelation. If possible, I would also check the aim of your antenna using a signal meter.
It is also possible that you have multiple stations conflicting with each other. The only way to check this is to know where you are located in relation to the broadcast towers. wysiwyggin’s suggestion of sharing your RabbitEars maps would help.
I hope you can get it all work out. While not perfect, the Tablo is a great product. It has already saved me about $4000.00. However, it is only as good as the signal it receives.
Consider getting a Televes antenna.
Consider contacting Antennas Direct they will tell you if the antenna you have is adequate for your distance from local broadcast towers and if the antenna you have is pointing in the correct direction. They have proven to be honest with me. Good luck. And ditto on it has been great investment for me. Nothing’s perfect and it could be better but for a plug and play OTA DVR with no monthly fee.
Thanks for the suggestion. I’ll post an update with any news.
