(Windows 10 using Century link DSL and 2 google chromecasts)
I have just installed a new unit with updates and connected to the wifi (the tablo was listed on the network and I connected - no problems)
The TV programs were uploaded and all was OK.
There were quite a few channel I didn’t want so I went into the setting and did an update, after that I couldn’t connect and what is worse after trying to connect my internet connection was then lost!
I had to connect to my internet again and the same thing happened when connecting to the tablo.
I rebooted everything - the same problem every time I try to connect to the tablo it breaks the internet connection.
(I have just tried the ethernet connection - and managed to connect - there us no way I can have a wired connection because of the locations of the router and tv)
I will work with you but I am not prepared to spend a lot of time - I will send it back, I am disappointed there is no phone support.
