Yep my thoughts exactly, you can definitely have up to 6 simultaneous streams going. For example, 3 devices can stream the same live tv channel, which is in fact only using 1 tuner.
Streaming already competed recorded shows does not use a tuner.
4 tuners = maximum of 4 simultaneous Live TV channels
Every Live TV channel after 4 would drop the Live TV viewing from the earliest tuned device.
First tuned in, first tuned out. ![]()
I verified at least 1 tuner is used for each channel, or subchannel.
Bet ya didn’t know this…
2 tuners for 1 channel will be used if all the following are true:
