Which setup method is best?
I just got the thing. I see the instructions show two ways to hook it up. Either with WiFi or the other way. Which way is better?
Ethernet if you have that option. The idea behind using WIFI was the Tablo can be placed where the OTA antenna was with out running a Ethernet cable.
Definitely ethernet if you have a location where you can connect to both the antenna and your router.
