Where does Tablo get time?
My Tablo seems to be a bit late on my recordings. I know how to extend the end -time of my recordings (and I do that), but I do not know how to “start early”. If the clock were correct, this would not be an issue.
Where does Tablo get its time?
I don’t remember setting the time during the setup procedure…
I think from the router, but @TabloSupport or @TabloTV will correct if I’m wrong.
The time on your Tablo is set by the Tablo servers based on your zip code.
The only way to have a show start early is to create a manual recording for that show. Manual recordings do work quite well for this sort if issue.
