Have ChatGPT notify you when A3SA approves a DRM technology other then Googles Widevine. Otherwise if you want a network tablo DRM will only work on android and that will be once A3SA approves the current network DRM proposals.
I am talking network based tablo devices. Apple uses fairplay. Microsoft uses PlayReady. Roku uses widevine but it doesn’t appear that Roku’s widevine will currently meet A3SA requirements. Are you expecting Samsung and WEBOS to fall in line with A3SA.
But my ATSC 3.0 stations (the few I have) are still unencrypted. And other local stations don’t appear to be moving to join ATSC 3.0.
In order for broadcaster’s to get what they demand, and allow for “something” (though not much from a consumer’s perspective), a method of end to end control (at all times for all devices and manner of use) has to be maintained. That is, it’s effectively grotesque no matter what. Broadcaster’s carry a lot of “weight”, but, they will do pretty much anything (emphasis) to get what they want here. Or, they will be content to let the whole thing “die” (which, in all fairness, with regards to “recording”, it pretty much what they want). If “tech” is the vehicle to get the “proper” ruling they wanted back in the 70’s… so be it.
Wait, did E. W. Scripps actually sell Tablo to Sinclair or is this a ChatGPT analysis of what would happen if Sinclair were to buy Tablo?
In any case, the analysis of what happens under ATSC 3.0 is probably very close to reality. My hope is that the FCC tells the ATSC committee that DRM will be forbidden for OTA subchannels, as it violates the concept of serving the public interest. I firmly believe that if the FCC forces the conversion, two things must happen: 1. DRM should be disallowed for OTA content (except if they are broadcasting a subchannel typically considered a paid channel like ESPN, HBO and the like for subscription and ONLY those channels). 2. The company that refused to join the patent pool for ATSC 3.0 should be told by the FCC that if they don’t join the pool, the FCC will not mandate a conversion to 3.0, severely affecting their future profits.
Wow. Just what we need. A technology that gathers up all of the garbage posted around the sewernet and summarizes it as if it is a factual and well- vetted report. Down the rabbit hole we go!
