There was no “watch” button for live tv. Ony options were “record” or don’t record. “Go to show” starts it all over again.
Which Tablo app are you using? If you’re on a smartphone, try tapping on the channel number directly, and it will take you directly to live TV.
Tablo tv app from the Play Store. I’m not on a smartphone. It is hooked up to the Vizio tv.
Are you still seeing the same issue now? Feel free to send an image of what it looks like to our support team, and we can guide you through it. You can also find a tour of the app here.
No, the watch button seems to be back for now. Thanks.
