Upgrading from older Tablo
I currently have the older Tablo 2 tuner model. If I plug my current hard drive into a new 4th Gen Tablo will my recordings still be available?
No, they are recorded completely differently.
Bummer. I don’t really want to lose all of those recordings. Do you know if they can be transferred into a viewable format on a PC?
Only if you can find a 3rd party ripper app that is still available.
I think you can install and use Tablo Tools, or Tablo Ripper on your PC to copy them from the Tablo to you PC.
MP4 format I believe.
Tablo Tools works great, but you do lose thumbnails and CS.
I left both Tablos hooked up at first until I watched all the shows on the old one. Then I sold it and the HD on Ebay. I installed a new HD with the new Tablo.
