Working PERFECTLY before up-grade. Now unit has ‘connectivity issues’ and no longer works.
I am having issues too with the new firmware 2.2.12.
What I have noticed is that if the Tablo is recording a show, then some or all of my AppleTVs are unable to connect. I can only connect after killing the recording (or waiting for it to complete).
I’ve submitted a support request regarding this.
I was recording at the 10Mbps setting… I just change dthat to the 8Mbps to see if that helps improve things.
Is your Tablo properly ventilated and cooled?
You don’t have it locked in a cabinet with 3 devices stacked on top of it?
Try turning it vertically so there is more service area for it to cool passively.
Hey folks - if you’re having issues, please contact us directly. We’d be happy to work with you to get things patched up.
Kudos to these guys they speedily replaced my unit once reported
DR
