Tablo was working fine. Updated successfully. It wanted to update the channel lineup and now claims there are no channels despite having 50+ before the update. Tried rebooting and is now stuck on a screen that says no channels. I guess I won’t be recording or watching tv for awhile
I had a similar problem - I had to change the zip code of my location and then run the scan. There may be a problem with the zip code to channel database. Try changing your zip code to a nearby zip.
Thanks. It was dead and I couldn’t even get to settings to rescan. Four hours later it’s working fine with no action on my part. Go figure
After an update, sometimes it has to process / update the database which can take some time. Tablo may be unaccessible during that time.
