Been using this since inception with little problems. Today, I went to rip some shows and got “Unexpected Exception… Object reference not set to an instance of an object”.
I restarted the app, restarted my computer, but same results. Didn’t try restarting the Tablo as it was recording something, but will try that next.
I used this a couple days ago and it worked fine. Any ideas what caused this and how to fix? Thanks.
