Please help, how to reintall driver after formatted with Tablo. My PC is unable to see this hard Drive.
Go to disk management under computer management in the control panel.
You need to go to disk management like User86 said and then reformat your drive for your PC. You can not use the drive on both devices without formatting it every time and loosing all data.
Thats because when the TABLO formats it, it uses a Linux EXT format, your Windows PC doesnt understand EXT (but uses NTFS) … there are 3rd party commercial drivers ($) that you can install which will let Windows read and write to an EXT formatted Linux type disk.
