Unable to delete recordings without restarting app multiple times. Roku Premiere version 11.5.0 build 4225-91 and Tablo dual 2.2.42 running 1.9.26 build 1024. Recording onto a WD My Passport 070A 2018 (319 GB).
When I finish watching a recorded program and request a delete the screen goes blank. I have to restart the app and request again, and nothing happens. When i restart the app a second time the recording is gone. Seems to have started after the recent Roku update a week ago. Have rebooted everything but no joy.
requires internet access… connected to your home network aka LAN. Tablo ripping suggest your PC isn’t isolated. [search “how insecure is windows 7”]
Thanks. Yeah, other threads are popping up with similar issues. Some people get the black screen when a,program ends, while mine occurs when trying to delete a recorded program. I suspect the cause is the same.
@TabloTV - the takeaway is that once the Roku purple screensaver is activated it will go to the black screen when you hit the back button. You can continue to watch the program and use fast forward, but when you hit the back button or the video gets to the end a black screen will be displayed.
TabloTV - my issue is similar but occurs at the end of a recorded program. When I try to delete it I get a black screen or the menu sits at the program description where you click delete. I have to exit the Roku app and go back in, then I find the program has been deleted.
