i connected a wired connection after that i wanted a wireless connection. cannot see network.
Maybe something like these instructions.
Paging @snowcat
Just follow the instructions @zippy provided.
Until it get the the iPad and IOS specific sections, then you may want to refer them to Connecting Tablo to Wi-Fi with PC since they think the problem is with Windows 7 - or since they are using a PC.
I donāt think you are going to find a complete document for every combination of situations and apps for all problems. That would be a ton of documentation.
It just requires users put their thinking hat on when the documentation gives some general directions.
You basically are unplugging the ethernet cable and rebooting to get tablo to output the adhoc SSID.
After that it depends on the app and OS. My PC is wired so I might have to adjust my thinking.
I didnāt intend to be rude. As much as I might have a clue what you just posted, and probably many other āregularā TabloTV Community postersā¦ Iād bet a ātypicalā user not understand the difference between WTF and SSID if itās an adhoc one
