So I have been having issues with my Table on/off for the past few months. It is at the point where it is not usable anymore such as sync issues and it can’t play recorded shows or live TV.
I have researched about all I could on this and still have no luck to make this thing even usable.
I was going to factory reset it but I came across a message by Tablo to say that this is an extreme measure and that you would only use it as a last option. I decided to send a message to Tablo support a few days ago offering to send logs (or whatever they need). I haven’t heard back so I am probably going to do a factory reset and hopefully it will reset whatever demons is plaguing my unit.
So… question is… why is a factory reset a last ditch option?
