Why is it impossible for me to get the time correct in the guide? Everything is correct I’m just three hours off.
I have the correct zip code and it’s never been anywhere but my home which has the correct time in the router.
Any ideas?
Any ideas?
I would call support, mate. I’m sure they can sort it out.
@camerabry - Check the time zone setting on the device you’re viewing Tablo on… If it’s off, it could be affecting things.
If that’s correct as well, pop a note over to support and we can patch this up for you: https://www.tablotv.com/ask-tablo/
Thanks. I’m having a tough time getting my router to open up the port to allow for remote viewing too so I guess I just need to call.
