Until today, I was using a 10 year old sit-on-a-table antenna that a friend gave me when he decided to completely cut the cord and built a good antenna set-up in his attic.
With that antenna I was getting 13 channels (including sub-channels and channels I didn’t want). This is pretty significant seeing as how I live in a north facing apartment in the north end of Toronto (all the broadcasters are south of me). I suspect I am getting signal bound off the building across the parking lot.
Today (having had the Tablo for a few weeks) I decided to see what I could get with a new (and supposedly better) antenna. I purchase a ClearStream from BestBuy on the way home. I chose it because it has been mentioned a few times in various forums and it was available at the store. The ClearStream does not include a signal booster (the old antenna has a signal booster).
The Tablo detects 25 channels, including sub-channels, 21 of which work. The other 4 are from 2 broadcasters that only get me 1 “dot” of signal strength. When I drop the channels I don’t care about, I’ve got 19 channels.
Remarkable what a better antenna can do.
I think tomorrow I need to go see if a signal booster will let me get those last 2 broadcasters and boost the 3 ‘dot’ channels to 4 or 5.
An interesting side-note: the Tablo tunes in stations that the TV doesn’t when connected to the antenna.
For those who haven’t given up reading this yet:
The new antenna is a Antennas Direct ClearStream Indoor/Outdoor Digital TV Antenna (C2-V-CJM-CN).
The stations are as follows:
NBC (one dot) + 2 sub-channels - won’t play
CBS (3 dots)
CBC (5)
ABC (5) + 2 sub-channels
CFTO (5)
PBS (one dot) +1 sub-channel - won’t play
TVO (5)
CW (3 dots) + 1 sub-channel
SRC
FOX (3 dots) + 2 sub-channels
Global (3 dots)
OMNI (3 dots) - the old antenna wouldn’t pick this up
MNT (3 dots) + 3 sub-channels
CITY (3 dots)
