Not sure what happened. Directly from the antenna to the tv fox was showing proper chanels.
But from Tablo the wheel of fortune was not in the guide and could not record it.
Prior to that had done a scan and updated the guide through tablo.
This again looks like a programming issue and not a server issue where always it is told for any issue there were issue with the server.
Same issue
Go to this Gracenote page and change provider to Antenna in your zip code. TV Listings- Find Local TV Listings and Watch Full Episodes
If Gracenote has the right programming data for the station then it is a Tablo problem. If Gracenote has the wrong data it is the station’s problem.
Than you @Ron1 this is great information ![]()
Samsung Tv does have a Guide option on the Remote and i did goo to the guide on the Remote and it was showing the program which was broadcasted @ that time
Same issue with KING5 (NBC) in Seattle, no programming data. Shows up correctly in Gracenote, all other stations are showing programming data in Tablo, including the .2, .3 etc stations
That sounds a lot like the problem with the NBC affiliate in Memphis. One OTA Channel Not Shown On LIVE But Still Records
