Hello, as of about 2 days ago the rogers media tower in my area had a failure. I lost connection to CityTV and Omni in Edmonton. I reached out to CityTV Edmonton and they said they were aware of the issue and they fixed it.
Usually when a tower goes down, the Tablo just doesn’t connect to the station, however this time the tower has been crashing my Tablo.
My friend who uses a HDHOMERUN, told me that some devices are able to stream the station, some devices can’t. And I have first hand seen that the tower is back up and broadcasting.
My Tablo is crashing every time I try to connect to the CityTV station, and giving me a “failed to connect - There was a problem communicating with your Tablo. If this persists, reboot your DVR”, all other stations work. I have rebooted my Tablo, rescanned the channels. I’m not understanding why this is happening.
Don’t know if this relates to your issue or not…
I too have an original 4-turner Tablo.
It used to be (2016-2017) that if you tried to record or view a “weak” channel, the Tablo would reboot. There seemed to be something about a station being “weak” as apposed to “no signal at all”.
I don’t know if this is still the case. I removed those weak channels some time ago.
Can you try removing the channel from your Tablo’s channel lineup completely, and then running a new channel scan and re-adding it? If this doesn’t fix the problem, send our a team a note and we can check it out.
Thanks that work, but l would like 1080p.
When trying to record it says weak signal. After changing settings I can now watch the Chanel but recording says weak signal change record setting to “HD 720P - 5 Mbps” and it works.
I had tried my tv and it’s the strongest channel 95 for strength and 100 for quality.
Boydadam, you live in Edmonton as well and are experiencing the same problem as me? Citytv was working on 1080p Thursday last week. My friends HDHOMERUN, he had to disable hardware acceleration to get the 1080 feed to work.
I will submit a ticket I guess, for a bit both stations were down, even on their 720p feed, then omni came back up at 1080p. Clearly they are doing something in the background.
I’ll reach out to Citytv once again and see if they have anything to say.
